Re: RDP drops in Mobility Controller tunnel
@ssnow wrote:
If this model can go to 6, I will see about upgrading the controller, if our model can be upgraded.
ssnow,
You probably do not have to upgrade.  That knob just makes it so that downstream broadcasts are not propagated.  You can accomplish the same thing by ensuring that as few people as possible are on that wired VLAN, so that traffic is minimized.  You can do that by creating a new AP group where the wired AP profile is attached to a VLAN that has few people or one person and see if you have the same issues.  If you are propagating a WLAN on those RAP 2Wgs, you can also enable "Drop Broadcast and Multicast" on that Virtual AP so that less traffic is propagated on your WLAN, as well....
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Occasional Contributor I
All four RAPs are on separate vlans with from one to six people on each. Perhaps the issue is how the uplink ports on the local switch are configured. This system was in place when I started with no documentation about the installation configuration.
Understood.
Are all 4 RAPs in 4 different AP groups?
Yes.
I have read your case and it is very similar with a problem that I had. How did you finally fix it?
Thank you in advance.
