MVP
Random Drops For Whole Site
We have been experiencing random drops in connectivity for a whole site a couple of times a day.  I noticed in the logs that it is showing the tunnel is going down and up but not sure how further to troubleshoot what might be the cause - can any one help? Logs below:
Virtual Mobility Master running Aruba OS 8.2.2.5
(BIRMINGHAM-AT-2) #show log system all | include TUN
Aug  7 14:47:03  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug  8 10:14:55  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug  8 10:15:01  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug  9 08:50:52  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug  9 08:50:59  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug  9 09:51:06  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug  9 09:51:11  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug 11 04:55:55  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug 11 04:56:18  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug 12 03:09:04  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug 12 03:09:21  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug 13 08:51:36  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug 13 08:51:53  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug 13 14:19:38  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug 13 14:20:01  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug 14 08:04:09  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug 14 08:04:33  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug 14 11:01:01  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug 14 11:01:24  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Aug 14 11:06:37  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_DOWN from IKE for default-local-master-ipsecmap
Aug 14 11:07:06  fpapps[3457]: <399838> <3460> <WARN> |fpapps|  Received TUN_UP from IKE for default-local-master-ipsecmap mapid 0x44a1, vlanid 9, flags = 0x2 uplink_priority 0
Re: Random Drops For Whole Site
On the master, type "show master-local stats" to see if any heartbeats are indeed being dropped between the master and the MDs.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
MVP
On the active controller on that site?&nbsp;
&nbsp;
Last drop was around noon today.  I would do a "clear master-local stats" to reset the counters and see how they grow in the next 24 hours.
MDs (controllers) do not need persistent connectivity with the MM.
MVP
Clear master local stats on the controller itself or on the mobility master?
&nbsp;
Also do you think maybe this is just showing the connection goes down between the controller and the MM - but that something else is causing the drop to the whole site as well as causing the issue with the communication to MM?
&nbsp;
Is there anything else i should be checking for in the logs ? I noticed this:
Just the controller, for now.
I would type "show log system 50" and see if there are any AP bootstraps.  If those APs are at the same site, and they have bootstraps, you have a local issue.
MVP
OK i have cleared the master-local stats
I did a show log system 50 but no AP boot straps
It is all the Aps and controllers on one site however that have the issue - happened again at 16:35 last night
MVP
Removed due to content
Is this a Virtual Machine?  I also saw a log before that said you are running this controller at 90% capacity, which is not advised (EDIT: 80% is the typical advice in a large network).
If this is important and you want this resolved quickly, you should open a TAC case.  There could be a number of things at play, here.
MVP
Mobility Master is running on Virtual Machines
The Mobility Devices are on site and 7005 Aruba Controllers 2 of them terminatiing only 10 APS and also around 200 clients - should be sufficient from my calculations
I think the usage you are referring to is the 90% AP usage set in the threshold list: Aug 14 11:01:46 :399838:  <3556> <WARN> |stm|  Resource 'Total APs' has exceeded  80%  threshold (actual:90%).
How do I check the usage or capacity of the device?
