Re: Random Drops For Whole Site
I don't think running at 90% numerically has anything to do with the performance.  It is just in the log.  I would have TAC take a look at your setup so that you can see if you even have an issue.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
MVP
So it seems there maybe an issue with our spanning tree settings which is causing a network topology change thus dropping the site in the process:
show spanning-tree:
Spanning Tree is executing the IEEE compatible Rapid Spanning Tree protocol
Bridge Identifier has priority 4096, address 20:4c:03:19:c5:b4
Configured hello time 2, max age 20, forward delay 15
We are the root of the spanning tree
Topology change flag is not set , detected flag not set , changes 96
Times: hold 1, topology change 35 hello 2, max age 20, forward delay 15
Timers: hello 0, notification 0
Last topology change: 0 days, 1 hour, 5 mins, 33 secs
So my question now is:
Can the Airgroup service function (i.e. discover devices) whilst spanning-tree is disabled on the controller?
We are in a situation where we only have spanning-tree enabled because we need multicast and broadcast traffic to be picked up by the controller.
I have read on the other threads in these forums that the controller will detect multicast on a trunked VLAN. Currently our ports on the wireless controllers are acting as 'access' ports.
Would switching these to ‘trunk’ ports, with spanning-tree disabled still enable Airgroup to function correctly?
Do you have your controllers dual-connected to the infrastructure?  If yes, you should disable spanning tree globally on the controller, and allow the infrastructure to handle spanning tree.  If no, still disable spanning tree and allow the infrastructure to handle it.
MVP
We are all for disabling spanning tree but we just need to know that the AirGroup discovery is going to work with spanning tree disabled?
Unrelated to Airgroup.
MVP
So can we disable spanning tree globally and AirGroup will still function with our current setup which is two access ports for two separate VLANs 9 and 12?
How are you using spanning tree?
MVP
Currently re-configuring our spanning tree setup and wanting to remove it from the controllers.
The only question we are now wondering about is does AirGroup functionality work the same through access ports? As this is how our current ports are configured.
Unrelated.
MVP
So the AirGroup feature would work regardless of the configuration of the ports (access/trunk) and with no spanning tree configured on the controllers themselves?
