Occasional Contributor I
Re: Remote Aruba WLC and Aruba AP
Inside the attachnemnt, you can see that there is IP address and also outer IP address?
Is there any relationship between this 2 IP address? Using NAT for the network address translation between the public and private IP address?
RAPs have an outer IP which is generally a public IP (but could be private if on another part of your network) which is used for the RAP to create a secure tunnel to the controller. The inner IP is used for actual AP communication between the AP and controller.
Looks like you have some APs provisioned as RAPs. Are they traversing the internet?
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
The RAP is located at the remote site Jakarta office. And all users conected to the RAP for internet. ANy concern?
