Hi all,
Previous version AOS 8.x when RAP and Remote Mesh Portal and Point can only terminate to a non-cluster controller. We have to designate a controller just for this purpose, no problem then and now.
After upgrading to 8.4, the cluster can terminate RAP and Remote mesh portal. However, the Remote mesh point is not as good. The point will not connect to the portal for a long period. We have to let the point run overnight, probably after multiple self-reboots and it would show up. If the point power cycle, same long period for point to terminate at cluster. Console to the point shows it sticks at DHCP, it could not get an IP address.
Environment: Point and portal are 303H, AOS 8.5.0.8. RAP and portal terminate at cluster of two 7220s. Portal provisions with static public VIP of the cluster, point LMS-IP is the internal VIP of cluster.
