MVP Expert
Replacing mobility master default https cert
I've just uploaded a new cert (m and CA chain onto our dev mobility master.
Problem is can;t see what I change to tell the master to use our cert instead of the default one. Is it . the Captive Portal  option in Conf/System/More/General ?
A
MVP Expert
Re: Replacing mobility master default https cert
Also,  When I then go to the controllers why do I have to pick a different cert name for same certs that I uploaded onto the mobility master. This is 8.5.0 BTW
Configuration> System> More> General.
The friendly name has to be different, because that is how you can tell which certificate you are choosing from the dropdown.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
MVP Expert
Ok , in our case we’ve got 1cert with multiple SANs and we’re using it on both the mobility master and the controllers
Sent from my iPhone
Is this for Captive Portal?  Captive Portal certfs on MDs/MMs only require a single fqdn.  Only Captive Portal certificates on ClearPass need multiple SANs.
MVP Expert
No, its for the cert you see when connecting to the management GUI
That would be under Configuration> System> Admin Authentication Options> Web Authentication> Server Certificate:
