Re: Routing base on VLAN and WebUI Error.
thank Singla.
I try to emulate IE 10 / 9/ 8 but the certificate revoked won't let me view the page. Any chance I can upgrade the firmware ?
MVP Expert
The controller can be upgraded.
Please share the ap types that you are using on the controller.
show ap database
hi .
Here is the show ap database output.
MVP Expert
Please mention the AP type as it is not clear in the screenshot
sorry.
The model is 620.
MVP Expert
Controller model is 620.
In the screenshot , you have a field called AP -type.
What is the model number of the access point ?
sorry again.
AP Type column is all 105.
MVP Guru
If you visit the HPE support site you can upgrade your controller to ArubaOS 6.4 which will in turn upgrade the AP105's. This release has support for later browsers. Ensure you read the release notes and follow the recommended upgrade path.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Thank you,
But I cannot find my Product Number on the device to add to HPE device list. Where to find my product number on 620 model ?
MVP Guru
The below output will give you the product number (serial)
(Lab-001) #show inventory
System Serial#                  : XXXXXX01
