Occasional Contributor I
SSID Profiles
Forgive me if this is a rudimentary question as I am still getting used to Aruba.
If I see a SSID profile that is part of a VAP profile and AP group and has this configuration:
g-basic-rates 5 6
Does that mean that only 5 Mbps and 6Mbps are supported on that SSID for 2.4Ghz and no 5Ghz support exists?
Thank you.
MVP Guru
Re: SSID Profiles
That is correct, you should see an entry for the supported A rates as well.
You can check with the following command:
show wlan  ssid-profile [SSID NAME]
-- TRUNCATED --
802.11a Basic Rates                               12 24
802.11a Transmit Rates                            12 24 36 48 54
802.11g Basic Rates                               12 24
802.11g Transmit Rates                            12 24 36 48 54
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Re: SSID Profiles
Thanks.  Just to make sure I understand, if I see something like this in an AP group:
ap-group "BLAH"
virtual-ap "blah-VAP"
wlan virtual-ap "blah-VAP"
aaa-profile "blah-MAC-Auth"
ssid-profile "blah"
vlan xxx
wlan ssid-profile "blah"
essid "blah"
opmode wpa-psk-tkip wpa2-psk-aes
wpa-passphrase blahblahblah
This ssid isn't being used at all since there are no supported 2.4Ghz or 5Ghz data rates?
Re: SSID Profiles
todbass10,
"show running-configuration typically only shows anything that differs from the defaults.   There is definitely more parameters configured. You would have to type "show wlan ssid profile <ssid profile>" to see exactly what is configured.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Re: SSID Profiles
Well that is inconvenient from Aruba.  Thank you for your help!
Re: SSID Profiles
If the show-running configuration showed everything, It would  be 10 times as long!
Re: SSID Profiles
I would be okay with that.  Unless there is a better solution to what I'm trying to do.  I'm looking at someones controller configuration to give some best practice recommendations.  Having to ask them to run 15 commands isn't very convenient.  Is there a better way to pull all the data?
Re: SSID Profiles
There is no command that shows every parameter in the configuration.
Internally at Aruba we use Visualcfg to audit configurations: https://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/EntryId/11880/Default.aspx
Maybe it will work for you.
Re: SSID Profiles
Bummer.  There should be.
I am using VisualCfg to review the config.
Thanks again.
