Highlighted
All-Decade MVP 2020
Re: Samsung Series 3 Chromebook connection issues
Since the CB cannot update the driver I guess this very much ties down to the driver compatibilities. If one is to deployed CB I would suggest to do a POC and check if the version is suitable before deployment elsethere will be a lot of work at the end of the day to try getting it working.
Normal Guy
