Serial number of secondary unit in vrrp stack
Where can I find seriel of secondary unit when 2 controllers are configured as Mobility controller with VRRP? Under Dashboar -> infrastructure GUI shows that I have 2 controllers but only shows information from primary. If i try to select secondary controller from GUI I get error that "configuration for the standby controller must be done at the mobility controller group level"
Also show inventory command only gives info about primary unit.
OS version is 8.4.0.1
Re: Serial number of secondary unit in vrrp stack
SSH into the secondary controller and type "show inventory | include System"
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
hmm. Already thought that I tested it but apparently I did not (or typoed the ip). Anyway that did the trick. Thank you for the quick reply.
