Occasional Contributor I
Setting NTP setting on multiple controllers
Hi, just looking for a way to set the NTP servers on 300 controllers. Could not find anything abvious with airwave.
MVP Expert
Re: Setting NTP setting on multiple controllers
It would depend a great deal on how you manage the controllers (in Airwave)
I use a template for all controllers and keep the management settings, AAA, and SSID details in the template. To change the NTP settings, just update one controller and import the changes to the template, or edit the template to include the changes and let Airwave update them all.
To answer how you should do it, we'll need to know how you are already managing them.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
We are only using airwave for monitoring. That is why i'm looking for other ideas like scripts, maybe
Frequent Contributor II
What OS version?
David
Sr. Trainer and Author of "Understanding ArubaOS: Version 8.x" book
MVP Expert
To do this in Airwave, I'd expect that you'd have to switch to managed-mode.
From a computer, I'd write a script (bash for myself, powershell perhaps for others) which would accept an input file with all controllers' IP addresses then just logs in, and sets the NTP servers.
--Matthew
