Hi guys,
I am newbie in the site surveys world and when I want to make signal strength measurements I always have the same problem. Some days ago I took an IAP to have an AP on a stick, and started to make signal strength measurements all around to check the wall attenuation. The problem is the signal strength constantly changes, -70, -63, -67, -80 dBm... I use InSSIDer and NetSpot and both have this problem. Furthermore, the signal strength values are different between these two applications, so which one to trust? And when I tried to take the measurements from my phone, it was even worse since I use Wifi Analyzer and the signal strength value changes even more. For those with hands-on experience on this topic? How do you take signal strength measurements? Any tip?
Julián
