Re: Signal strength measurements
Hi ohsung.kim,
Thanks for the information. I have checked it out with my Android and it tells you a lot of info about Wi-Fi such as RSSI, MCS, transmit power and many more. Very useful :)
Julián
You may also want to try the mobile versions of different professional survey tools. For example, AirMagnet/Ekahau/iBwave all have Android based survey solutions that use the Wi-Fi radio on the mobile device (phone or tablet) to collect the data.
