Highlighted
MVP Expert
Re: Site Survey with IAP Manual
There seelct only - enforce uplink to eth0 and make sure it is in standalone mode
try that and let us know how it goes
Highlighted
Frequent Contributor II
got it working now:
when i checked the filed "disable ssid on uplink failure" it works. But i thought i have to uncheck it. With cli "show configuration" i saw that it is the opposit.
Highlighted
MVP Expert
Interesting, maybe that label needs re-wording
Highlighted
OK I got this to work but it takes over 6 minutes for the AP to boot and the radios to come up. Is there anything I can do to get the AP to boot faster.
Pat
Highlighted
i have some new problems with site survey and IAP
ArubaOS (MODEL: 115), Version 6.4.2.6-4.1.1.7
wlan ssid-profile SiteSurvey
 enable
 work-without-uplink
 index 0
 type employee
 essid SiteSurvey
 wpa-passphrase 0***************************
 opmode wpa2-psk-aes
 max-authentication-failures 0
 vlan guest
 auth-server InternalServer
 rf-band 2.4
 captive-portal disable
 dtim-period 1
 inactivity-timeout 1000
 broadcast-filter arp
 dmo-channel-utilization-threshold 90
 local-probe-req-thresh 0
 max-clients-threshold 64
uplink
 no preemption
 enforce ethernet
 failover-internet-pkt-lost-cnt 10
 failover-internet-pkt-send-freq 30
 failover-vpn-timeout 180
 uplink-priority ethernet 1
 uplink-priority wifi 2
 uplink-priority cellular 3
but it is rebooting every 10Minutes and shows
Reboot Time and Cause: AP rebooted ***********; Gateway unreachable
Please Help! i got it working once but changed firmware often since then.
Highlighted
Hi, jAyR. Did you find a way to keep the AP from rebooting?
We have an AP105 with older firmware 6.3.1.2 that works just fine in standalone mode for surveying, but our new AP275 with 6.4.3.1-4.2.0.0 is rebooting constantly with the same "Gateway unreachable" reason.
Highlighted
for me it is working now . i have configured static ip, "work without uplink" and i think i needed to set :
swarm-mode Standalone
Highlighted
Thank you, jAyR. I just had to add the "swarm-mode Standalone" and now the reboots are gone:)
So it looks like two commands will do it:
"swarm-mode Standalone" - to stop the rebooting
SSID profile - "work-without-uplink" - to broadcast the SSID
Highlighted
To summarize:
ACMX, ACDX, ACCP, MASE
View solution in original post
