Highlighted
Re: Site Survey with Standalone AP
Make the ARM mode Disable.  Then the AP will set itself to the channel and power in the radio profile.  Scanning has no effect when ARM is disabled.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
How can you find what dBm your AP is set at in the console?  Thanks
Highlighted
Highlighted
I will check it out  ----  many thanks!!
