We currently have two controllers which are configured as standalone / standby. When the main controller is no longer alive the standby controller is running.
AS i can see there are three configurations:
- The mobility master configuration (mm) (192.168.200.140)
- The node configuration (standalone) (192.168.200.141)
- The other node configuration (standby) (192.168.200.142)
I noticed that when i switch off the standalone, the master configuration on the standby is not identical to the standalone controller.
I checked the nodes configuration and they are perfectly the same (Except for IP / hostname). How come the mobility master configuration is not identical on both controllers?
Furthermore, i have posted the database sync below.
<----Display of show database sync from standalone----------------->
Last L2 synchronization time: Fri Dec 20 07:44:59 2019
Last L3 synchronization time: Secondary not synchronized since last reboot
To Master Switch at 10.100.200.142: succeeded
WMS Database backup file size: 96909 bytes
Local User Database backup file size: 49536 bytes
Global AP Database backup file size: 14964 bytes
IAP Database backup file size: 3751 bytes
Airgroup Database backup file size: 3055 bytes
License Database backup file size: 4943 bytes
CPSec Database backup file size: 3248 bytes
Bocmgr Database backup file size: 6017 bytes
L2 Synchronization took 8 second
L3 Synchronization took less than one second
87 L2 synchronization attempted
4 L2 synchronization have failed
0 L3 synchronization attempted
0 L3 synchronization have failed
L2 Periodic synchronization is enabled and runs every 30 minutes
L3 Periodic synchronization is disabled
Synchronization doesn't include Captive Portal Custom data
<----Display of show database sync from standby----------------->
From Master Switch at 10.100.200.141: succeeded
90 L2 synchronization attempted
3 L2 synchronization have failed
<----Display of show database sync from master mobility----------------->
Last L2 synchronization time: Fri Dec 20 08:15:01 2019
WMS Database backup file size: 97851 bytes
Local User Database backup file size: 49550 bytes
88 L2 synchronization attempted
