Re: Student Residences and Inability to Connect to College-installed APs
Try switching to AES on your WPA.
Zach Jennings
@tmondschein wrote:
What VLAN does a user end up on in the residences?  Is it different from everywhere else?
Students are placed in1 of 6 VLANs if AP is terminated on the Local; 1 of 3 VLANs if AP if terminated on Master.
Is it possible that one of those VLANs does not exist on the local controller, so when a user ends up in that VLAN, he gets nowhere?
Type "show vlan status" on that local controller to make sure.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Please keep in mind that WPA-TKIP does not support 802.11n rates. I just tested this on an AP-105 sitting right next to my MacBook Pro. After I switched it over to AES, the MacBook Pro then connected at 802.11n rates. Hence my recommendation for switching over to AES.
Zach Jennings
Occasional Contributor I
All 9 student  VLANs are "Enabled" as reported in the Adminstate and are "Up" as reported in the Operstate listing in both the Master and Local controllers.
We do use VLAN-pooling, as recommended by Alcatel support reps and technicians.
I will look into changing the WPA-TKIP to WPA-AES.
Have the student connect the Mac to a hardwired port and update the driver for the NIC.
We had this problem last year.
