We have an IoT device that only supports 2.4GHz and it is configured through a phone app. The phone is connecting at 5GHz. I think that if both devices are on the same BSSID, the configuration process will work and after that, I think the phone can go back to 5GHz as behind the scenes they are on the same VLAN.
It looks like one should be able to use some form of a command with move-sta to force a device to a particular BSSID. I've tried the "arm move-sta" version of the command to no avail. I'm not sure that is correct with MMs managing the RF. Is there a way to do this in ArubaOS 8.3?
Robert
