Hi brains, just wondering if anyone could perhaps shed some light on why an IAP that reports in logs that it's successfully been upgraded from 6.5.4.6 to 8.6.0.2 just gets stuck at the verifying config stage in Airwave? Not sure what we're doing wrong... we duplicated the group, changed the firmware version setting, moved the AP and VC that we wanted to upgrade into said group and let Airwave work its magic (*edit: not sure if I need to mention that the VC and AP are same device at 1 small remote site). Only now we can't access it by IP although if I look at our firewall logs I can see the IAP sending packets to random NTP servers. I can do packet captures but unless there's something fairly specific I should be looking for then I'm not sure it would be worthwhile as I'm not too familiar with understanding the captured data or what to look out for.
Any advice would be appreciated as we have a lot of firmware to upgrade and don't want to have to do them all manually.
Michelle
