we currently have 1 Moblity Controller with 20 AP.
We created 4 SSID using 4 different VLAN (VLANs 2 - 3 - 4 - 5)
These 4 VLANs are obviously also present on the Switch-Core and the DHCPs are on the S-Core as well.
My question is: in order for the clients via WiFi to work correctly etc, do I need to propagate the VLANs on the Uplink between remote-switch (where the APs are physically connected) and switch-core (and also create the L2 VLAN on the remote switch)?
Or is it enough to propagate the VLANs between Switch-core and controller?
Thank you
