hno
VMC LC-Cluster L2 Connection (ESX)
Hello Airheads,
i have ArubaOS 8.3.x running (2x VMC on VLAN 81 and 2x MM on VLAN 80).
My problem is that L2 cluster works fine as log as both Cluster-VMCs running on the same VM-Host. If one is migrated to an other host, the L2 cluster is broken.
But all maschines are always reachable by IP. And VRRP works also.
Only the L2 Connection is gone.
Must be something on the VM side, i think.
Any suggestions?
Thank you!
