Highlighted
VPN Configuration for remote AP mode
HI All,
My question about VPN configuration for remote AP , actually AP is in the same site with the controller but i used the remote mode because i have only one controller and i need to keep SSID broadcasting if the controller is down , my question about the VPN Configuration needed for this situation considering that both in same site already not a branch site , what should i configure in steps?
Highlighted
Re: VPN Configuration for remote AP mode
My colleague just wrote a very detailed paper on how to configure remote AP here:  https://support.hpe.com/hpesc/public/docDisplay?docId=a00097853en_us
Please keep in mind that configuring remote AP in a campus setting is very nonstandard.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
If You use AP as Campus it should be within the organization internal network Managed by MC. If Config as RAP, it should be outside from the network but managed by MC.
But Campus AP/RAP your data/management traffic securely communicate via a GRE tunnel.  No need to create another VPN to the corporate network.
Dinusha Chandrasinghe
Network Engineer -Enterprise System Solution @PlexusGlobal
ACMP | ACSP | ACCA | MCSA
