Highlighted
Contributor II
Re: VPN problems
I'm confused though because I assigned the auth-guest role to the CP profile for the "Default Role" but I see that there's a "Default Guest Role" there as well with "guest" as the default setting. It seems that this role is what is being applied to the users. What's the difference between the two?
Highlighted
Re: VPN problems
@arubamonkey wrote:
I'm confused though. I assigned the auth-guest role to the Captive Portal default role but there's also a "default guest role" there with "guest" as the default setting. What's the difference between the two?
The Captive Portal default role is the role users get when they authenticate with a username and password, UNLESS the server group attached to the captive portal authentication profile has the server derivation rule has "set role condition Role value-of" which means "take the role that the user is assigned in the local database and override the Captive Portal default role.  The default guest role is what the user is assigned if the captive portal authentication is "email address only".
In recap:
- Captive Portal users who authenticate with username and password get the Captive Portal default role, unless that user derviation rule in the server group, which would mean they get the role assigned in the local database instead.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Contributor II
Re: VPN problems
Well, the users I have are using accounts created using the guest provisioning page, so yes, they have to login with a username and password. This means that they should get the auth-guest role as that's what I have assigned under "Default Role" in the CP profile no the guest role under the "Default Guest Role". I don't know where this "email address only" option is.
Highlighted
Re: VPN problems
But, in the local user database, the user has a role of guest, so combined with that "set role condition Role value-of" server derivation rule (In the Default Server Group), the role becomes guest.
Highlighted
Contributor II
Re: VPN problems
Where's this local user database where the role is guest?
Highlighted
Re: VPN problems
Type "show local-userdb" and you will see it.  Please also consult our guest Validated Reference Design for many more details on guest access here:  http://www.arubanetworks.com/pdf/technology/AOS_GuestAcccess-AppNote.pdf
Highlighted
Contributor II
Re: VPN problems
Ah! So you're telling me that when a guest account is created using the guest provisioning page, it is assigned an automatic role of "guest"? Is there a way to change this?
Highlighted
Re: VPN problems
Yes, it is.  It cannot be changed.
Highlighted
Re: VPN problems
Was your VPN prolem resolved?????
I am having same Issue, My controll running on IOS 5.0.3.3.
Guest user can not able to Loging to thier outside VPN.
Please provide me detail information, if anybody resolve this issue....
Highlighted
Re: VPN problems
jnlimbachia,
What VPN are your guests using?  What is your perimeter firewall?  Are you allowing VPN traffic in your guest role?
