Highlighted
MVP Guru Elite
Re: Virtual Mobility Controller and IAP-VPN
You can deploy certificate using AirWave
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Contributor II
Do you know which certificate upload option is the one to be used? I already asked that before but noone replied. Is it the custom SSL cert?
https://community.arubanetworks.com/t5/Wireless-Access/VMC-Scalability-for-IAP-VPN-and-Multizone/td-p/433954#
Thank you very much.
Highlighted
MVP Guru Elite
for me, it is the Server Cert
Highlighted
Contributor II
Thank you very much. Pity the config is not more straight forward on cert configuration for the VPN connection. I will give it a try as soon as the customer green lights the test.
Highlighted
All-Decade MVP 2020
Hi JoseAngel, were you able to get this working?
Can you take me through what you did?
Scott
