WE ARE PLANING TO USE THIS OUT DOOR DEVICE TO MAKE POINT TO POINT CONNECTION BETWEEN ARUBA IAP 274 AND I WANT TO KNOW WHAT IS THE MAXIMUM DISTANCE IT WILL COVER TO GET A POINT TO POINT CONNECTION .
KIDNLY CHECK AND UPDATE AS SOON AS POSSIBLE
I AM WAITING FOR YOUR REPLAY
THANK YOU
