Highlighted
MVP Expert
MVP Expert
WPA3 backward compatibility issue
Hi community,
Iam testing the new WPA3 feauture that recently comes out in ArubaOS 8.4.0.0. I have a IAP-325 in CAP mode managed by a MM. Far as i know is WPA3 backwards compatible with WPA2 devices.
I create a "next-next-finisch"  SSID with WPA3-Personal.
  • When i connect with my Windows 10 notebook it connects in the right way and fall back on WPA2.
  • When i connect with my iPhone8 or iMac it dont connect and fails with a PSK wrong password error.
  • [update] When i connnext with a adrioid (galaxys8) PSK also failed.
Somebody got a idea why apple product seems to be not fall back to wpa2?
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
Highlighted
Re: WPA3 backward compatibility issue
Is your Windows 10 machine an Intel Wireless Adapter?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
MVP Expert
MVP Expert
Yes its a Intel Dual Band Wireless-AC 8260
Highlighted
MVP Expert
MVP Expert
Highlighted
MVP Expert
MVP Expert
I found that the windows 10 client is also unstable, high ping rate of 300ms and higer when connect to the HomeLab-WPA3 ssid.
When i connect back to  HomeLab-WPA2 ssid, all pings are back to normal at 8ms.
Even the windows 10 Client (build 1709) WPA3 PSK is not connecting anytime in the correct way, sometimes it connects, othertime the PSK is timed-out.
Maybe iam to fast with testing this brand new feature, or maybe i missed something . But based on my first experience  is that itsnt really backwards compatible to wpa2 right now.
Any body some tips or equivalent experience?
Highlighted
Occasional Contributor I
Did you ever find some resolution to the issue?
I am trying to connect my win7 laptop with the same wifi card running the latest intel drivers and cannot get connected. My iphone & adroid can both connect to the new WPA3 SSID without issue.
I am running an Ap515 v8.4.0.0 in IAP mode
Highlighted
I also have WPA3 backward compatibility issues:
Aruba AP-303 Firmware 8.6.0.2
Client: OnePlus5
1. Client tries to connect to a new WPA3-Personal protected Wi-Fi network (network is shown unprotected in client);
2. Client cannot connect. No probes, associations, no wireless traffic from client is available in Wi-Fi trace;
3. Change network protection from WPA3-Personal to WPA2-Personal;
4. Client can connect immediately (network is shown protected in client);
5. Change network protection from WPA2-Personal to WPA3-Personal;
6. Client stays connected. When disconnected, it can reconnect without any problems;
7. Remove the known network in the client;
8. Client cannot connect. No probes, associations, no wireless traffic from client is available in Wi-Fi trace;
Same issue on Canon wireless printer (MG5650)
Windows client can connect without any issues, even when its a 'new' network.
Can be a client issue, but has anybody found a solution?
Highlighted
Frequent Contributor II
Hi
I haven't seen the problems you are facing, but have had a couple of TAC cases lately, and they started by asking me if the customer was running WPA3.
This might just be a coincident, but it got me thinking at least.
If i'm informed, Aruba should post a new patch for both 8.6 and 8.5 today i was told. Remains to see if there are any changes towards WPA3.
Roar
Highlighted
Just tested with firmware 8.5.0.7_74786. Exactly the same behaviour.
Made a WLAN trace from the AP: not a single frame (for example probe) is seen from the client when WPA3 protection is enabled. Strange.
Will make a new trace with seperate WLAN dongles. I should see probe frames from the client, if not is should be a client issue. Will take some days, currently the needed hardware is not available.
Highlighted
Today made an airtrace of the authentication proces.
WPA2-PSK:
- Auth Key Management: PSK
- OnePlus 5 starts association and connection is succesful.
WPA3-SAE with WPA3 transition mode:
- Auth Key Management: PSK & SAE
- OnePlus 5 does not start association after probe response. Although PSK is avaible, association is not started.
WPA3 is not backwards compatible on all Wi-Fi clients!
Surprise surprise.
