Re: What kind of authentication I should use?
You should add PEAP to the Remote access policy on the radius server, even if you don't have a certificate.  Also make sure you have 802.1x termination on in the 802.1x profile on the controller.  Make sure your client is also configured with PEAP.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
GREAT!!!!! it is working now cjoseph!!!!!
Thanks very much for your help. I just activate the 802.1x termination on the controller and started to works!
Thanks again for your help!
Glad we could finally get it to work!
