Highlighted
Occasional Contributor I
Re: Wireless Speed
client is near to the AP and on the wireless ststus it is displaying 54 mbps.......
Highlighted
Re: Wireless Speed
The wireless status where?  Windows?  That has errors quite a few times.  The controller says your client is associated at 802.11n.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Valued Contributor I
Re: Wireless Speed
Have you run any performance/throughput test on your client device? This could be just the OS mis-reading the NIC or a graphical issue only. Try iperf or jperf. Those are good for telling. If it is only running a lower rate, try updating the NIC driver if it's old.
Kudos appreciated, but I'm not hunting! (ACMX 104)
