Wireless + licensing
Hi people,
I have a question regarding a customer environment.
They want to go ahead with the following equipment in their situation:
  • 85 AP515 Aruba Accespoints  + mount kits
  • 7x Aruba AP-365 + mount kits
They are using airwave and a virtual controller. They will need the licensing voor their AP's. Pef and LIC if im not mistaking. Do they also need new licensing for their airwave part?
Please let me know if you can help me since this is new to me.
Thanks in advance!
Regular Contributor I
Re: Wireless + licensing
You will need:
92x AP license
92x PEF license
93x Airwave license (1 per AP, 1 for the controller)
If you add a mobility master to the configuration you can use clustering (2nd controller needed), airmatch, multizone, etc. in that case you would need to add 2 packs of 50 MM bundle licenses.
Don't forget to add software support.
- - - - Aruba ACCX #748, ACDX #758, ACMP, ACEAP | HPE Master ASE - - - -
- - - - - - - Feel free to give kudos or accept as a solution! - - - - - - - - -
I'm looking at purchasing a 7205 controller with 46 APs.  So I'll need 46 -JW472AAE - (Aruba Controller Per AP Capacity License AP license) and then do I also need a controller license?  If so, whats the sku?
Thanks!
