I'm having a weird problem with a wireless mesh point. I'm trying to replace a 20 year old nortel switch that the 374IAP is connected to. The mesh is working while connected to the nortel switch. I've configured the ports as identical is I can. The Mesh Portal is also a 374, and the cluster is on v 8.6.0.4
When I connect the IAP to my new cisco 9300, the access point is no longer able to form the mesh. I can only assume that the problem is with the configuration on the cisco switch.
Here is my port configuration:
interface GigabitEthernet1/0/2
description Mesh to offices
switchport trunk native vlan 2527
switchport trunk allowed vlan 1,908,909,2360,2507,2527,3407
switchport mode trunk
2527 is the management vlan for the access points.
Any help is appreciated
