Wrong passwords between MC and MM / MM and MM
  • 1.  Wrong passwords between MC and MM / MM and MM
    Posted Jun 30, 2020 04:35 AM
    how can i troubleshoot this issue and find the root cause
    OR MM and MM
  • 2.  RE: Wrong passwords between MC and MM / MM and MM
    Posted Jun 30, 2020 06:00 AM
    In your Mobility Master (MM) there will be a line(s) in the configuration for each of the Mobility Controllers (MCs):
    localip <controller-ip> ipsec ******
     To find it easier and to de-encrypt the ipsec PSK try this:
    cd /mm
    encrypt disable
    show configuration effective | include localip
    Try setting this PSK to what you configured during the full-setup phase of the controller.
    For the MM redundancy (MM to MM)  the ipsec key is configured under 'master-redundancy'. Look for the following:
    peer-ip-address <MM-peer> ipsec <ipsec-key>
    This needs to be the same at both MMs.
    Remember to 'encrypt enable' when you're done.
  • 3.  RE: Wrong passwords between MC and MM / MM and MM
    Posted Jun 30, 2020 08:05 AM
    how can i check the error by the debug ???
  • 4.  RE: Wrong passwords between MC and MM / MM and MM
    Posted Jul 01, 2020 02:28 AM
    As it's IPsec auth failure you would be looking for IKE failure in the ipsec related debug logs. One of these will do the trick:
    logging security process crypto level debugging
    logging security subcat ike level debugging
    logging security process authmgr level debugging
    Maybe something like this: <6280> <DBUG> |ike| 10.10.10.99:500-> I <-- Notify: AUTHENTICATION_FAILED (IKE)
    Remember to turn off debug level logging after you're finished.
