Highlighted
Zigbee 802.15.4 radio supported APs
Where can find "Zigbee 802.15.4 radio" supported APs list or in AP matrix?
Highlighted
Aruba
Re: Zigbee 802.15.4 radio supported APs
The only APs with integrated 802.15.4 radio are the recently launched AP-303P (303 Series Campus Access Points) and the future 11ax AP platforms.
In order to use Zigbee on existing APs, you'll need a USB dongle (and software support).
/Onno
Highlighted
Is there any solutions in Aruba for that USB dongle and Software or should be a 3rd party product?
Highlighted
Aruba
Nothing available now, but that may change in the coming months. Whether using an Aruba or third-party dongle, the solution will come from Aruba.
/Onno
Highlighted
Thanks for your info Onno.
Highlighted
MVP
At Atmosphere '19 last week, there was a booth demonstrating an Aruba AP with a zigbee USB stick - I wasn't able to spend enough time at the booth due to my training schedule, but it appeared to work.
Now I need to know which USB dongles work and which Zigbee products are compatible.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Highlighted
MVP Expert
Was it the shelf tags or was it the door lock system? Right now, to the best of my knowledge, support for any Zigbee solutions are solution-specific, and not more broad to support any Zigbee system right now. AFAIK we have engineering projects for door locks from one vendor (Assa Abloy) and one engineering project for shelf tags (can't remember the vendor).
Jerrod Howard
Distinguished Technologist, TME
Highlighted
MVP
It was the door lock system.
We have lighting control on a parallel network with 4G uplink and the zigbee mesh is failing (age and cheap hardware with a deunct vendor) so we're looking to bring it over.
Sounds like I'll be holding my breath a while longer.
--Matthew
Highlighted
MVP Expert
Escalate up through your Aruba rep, you never know ☺ But I know we’re exploring the zigbee ecosystem for options, but it requires a desire from the other side’s vendor ☺
Jerrod Howard
