aaa authentication mgmt will not get inherited throught two levels
  • 1.  aaa authentication mgmt will not get inherited throught two levels
    Posted Aug 11, 2020 03:42 AM
    we tried to configure our TACACS Servers as authentication servers for our MD's.
    But the server-group was not pushed from our first level (orange, first sub-folder of Managed Networks) trought two levels to the controllers.
    The TACACS server and the TACACS server group were pushed correctly.
    Is this an expected behaviour that the configuration will not apply throught several levels?
    Thanks.
    David
  • 2.  RE: aaa authentication mgmt will not get inherited throught two levels
    Posted Aug 11, 2020 06:22 AM
    Configs done at /md level should get pushed down to lower levels ( customer groups & WLC's)
    Please check if you still have any pending changes ( WebUI Right hand corner)
    Moreover the CLI outputs attached from your end shows that server-group for mgmt auth is configured at MM level rather than MD level
    Please log in to CLI and share the following output:
    Aruba[mm] #cd /md
    Aruba [md] #show configuration pending
    Aruba [md] #show configuration committed | begin "aaa authentication mgmt"
    Aruba[mm] #cd /md/<name of group at first level>
  • 3.  RE: aaa authentication mgmt will not get inherited throught two levels
    Posted Aug 14, 2020 09:29 AM
    There were no pending changes.... We checked multiple times.
  • 4.  RE: aaa authentication mgmt will not get inherited throught two levels
    Posted Aug 15, 2020 07:18 AM
    I think for admin account, it is per-device settings.
    Try make admin account on MM, it will not be replicated/pushed to MD..
    Best Regrards
    Yopianus Linga
  • 5.  RE: aaa authentication mgmt will not get inherited throught two levels
    Posted Aug 21, 2020 05:51 AM
    Please share these outputs:
    Aruba[mm] #cd /md
  • 6.  RE: aaa authentication mgmt will not get inherited throught two levels
    Posted Aug 28, 2020 08:30 AM
    We configured our TACACS Servers in the lower sub folder.
    Unfortunately it was the only way for us to get it running.
  • 7.  RE: aaa authentication mgmt will not get inherited throught two levels
    Posted Aug 28, 2020 09:19 AM
    If you haven't, please open a technical support case in parallel so that they can replicate the issue in your environment.
