Re: addition failed as max limit has been reached - but why?
yes, found it! thank you very much
Hello again,
can there occur some problems with the virtual maschine? Just shutdown, change specs and restart? Because it is a linux-system it could be critical no?
Thanks in advance,
raffael
That is all that you need to do.  There should not be a problem with changing the specifications as long as your hardware supports it.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
To be clear, shut down the VM, change the memory and processor to what is in the document.  When you restart the VM, look at the console messages while it is booting up to monitor the status of the VM.
