Highlighted
Re: ap database not syncing
You sure your AOS is 6.3.1.2 and not 6.1.3.2?
Highlighted
Frequent Contributor I
6.3.1.2
David M. Zeising
Network Engineer|Scottsdale Healthcare
Work 480.882.4996 Cell 480.993.5218
E-mail: Dzeising@shc.org
[cid:image001.png@01CF39E9.797CA9D0]
The information contained in this message is confidential and intended solely for the use of the individual or entity named. If the reader of this message is not the intended recipient or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution, copying or unauthorized use of this communication is strictly prohibited. If you have received this by error, please notify the sender immediately.
Highlighted
SCREENSHOT YOUR MONITORING>CONTROLLER SCREEN (the one with the sync success or not.** < post it here please>
Highlighted
Actually, TAC just called, will continue with them, thanks for the help...
Highlighted
Sure,always glad to assist  - Just please let us know what was the issue and how it solved.
Highlighted
one last thing - tell TAC that u got 6 missing hearbeats between the controllers from today.
advise: *check the connectivity between the master & your lcoal*
Missed -> HB Resp from Master
IP Address HB Req HB Resp Cfg Terminate Peer Reset Total Missed Last Sent Missed Last Synced/Last Missed
xxx.xxx.254.247 447962 447962 0 0 6 0 Fri Mar 7 09:37:41 2014
Highlighted
I was told this is a known bug with 6.3.1.2 and is fixed in 6.3.1.3 we were able to move an ap over to the master and it functioned normally, seems to be a nuisance bug, not affecting performance.
David M. Zeising
[cid:image001.png@01CF39ED.D77F4BB0]
View solution in original post
