thanks,I will open a case。
show inventory
Supervisor Card slot : 0
System Serial# :
CPU Card Serial# :
CPU Card Assembly# : 2010219H
CPU Card Revision : (Rev:07.00)
Interface Card Serial# : AI49050387 (Date:12/10/18)
Interface Card Assembly# : 2010085E
Interface Card Revision : (Rev:04.00)
SC Model# : Aruba7240XM
HW MAC Addr : 00:1a:1e:05:85:18 to 00:1a:1e:05:85:1f
CPLD Version : (Rev: 3.0)
Power Supply 0 : Present : Yes (Not Functional)
: 12V OK : No
: Fan OK : No
: Aruba Model No : 2510057
: Vendor & Model No : QCS DCJ3501-01P
: Serial No : QCS180620AH
: MFG Date : 2/7/18
: Output 1 Config : 12V 350W
: Input Min : 90V AC
: Input Max : 264V AC
Power Supply 1 : Present : Yes
: 12V OK : Yes
: Fan OK : Yes
: Serial No : QCS183921DH
: MFG Date : 9/28/18
Main Board Temperatures :
: U24 - Local Temp 35 C (shadow of XLP heatsink)
: Q1 - Remote 1 Temp 38 C (shadow of VRM, VDD_CPU)
: Q2 - Remote 2 Temp 36 C (shadow of VRM, VDD_SOC)
: U44 - Local Temp 27 C (shadow of DPI connector)
: U29 - Remote 1 Temp 40 C (XLP die temperature)
: Q36 - Remote 2 Temp 30 C (shadow of 98X1422)
: J2 - DDR A Temp 27 C (DDR3 A temp)
: J4 - DDR B Temp 28 C (DDR3 B temp)
: J1 - DDR C Temp 27 C (DDR3 C temp)
: J3 - DDR D Temp 28 C (DDR3 D temp)
: Port 0 Temp 148 C (1G PHY temp)
: Port 1 Temp 148 C (1G PHY temp)
Interface Board Temperatures :
: U21 - Local Temp 28 C (shadow of port 1 RJ45)
: Q4 - Remote 1 Temp 28 C (shadow of 88E1543)
: Q3 - Remote 2 Temp 34 C (shadow of 88X2140)
Fan 0 : 9060 rpm (5.450 V),Speed Low
Fan 1 : 8936 rpm (5.405 V),Speed Low
Fan 2 : 8957 rpm (5.495 V),Speed Low
Fan 3 : 8926 rpm (5.450 V),Speed Low
Main Board Voltages :
ispPAC_POWR1014A_A :
: 1V2 1.20V sense 1.230 V
: VDD SOC 1.050V sense 1.048 V
: VCC IOBD 1V5 1.50V sense 1.524 V
: DDR3BD_VTT 0.75V sense 0.748 V
: VCC 1A 1.00V sense 1.022 V
: IV8_DIGITAL 1.80V sense 1.858 V
: 3V3_MAIN 3.30V sense 3.342 V
: VCC1 1.00V sense 1.018 V
: VCC25 2.50V sense 2.520 V
: 3V3 SB 3.30V sense 3.342 V
ispPAC_POWR1014A_B :
: VDD 1.100V sense 1.100 V
: VCC IOAC 1V5 1.50V sense 1.524 V
: DDR3AC_VTT 0.75V sense 0.754 V
: VDD_SRAM 1.00V sense 1.044 V
: VCC1B 1.00V sense 1.026 V
: 1V8_ANALOG 1.80V sense 1.836 V
: 1V8 1.80V sense 1.844 V
: VDDIO12_XAUI 1.20V sense 1.224 V
: 5V 5.00V sense 4.986 V
Interface Board Voltages :
ispPAC_POWR6AT6 :
: VCC33 3.30V sense 3.378 V
: VCC 18 1.80V sense 1.858 V
: VCC1 1.00V sense 1.030 V
: VCC12 1.20V sense 1.220 V
: VCC12-DVDD 1.20V sense 1.208 V
: VCC9 0.90V sense 0.928 V
