This community is currently in a read-only state due to a maintenance window. For more info click here
Highlighted
aruba wired clients
since I have upgraded our MM to the latest version 8.6.0.4 I can see some wired clients on the MM dashboard, connected on different MD controllers. this one didnt happen with the last version 8.5.0.4.
I cannot see the MAC addresses from these wired clients on the network/switches and using MAC finder on Internet it's showing me Cisco.
did anyone have the same problem ?
Highlighted
Re: aruba wired clients
Typically that is because you changed one of your wired interfaces on and MD or the MM and made them untrusted.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
hi,
thats weird, I dont think the config has been changed after upgrading to 8.6.0.4 and in the old AOS 8.5.0.4 there was no entrie with wired users on the MM dashboard
Highlighted
Please open a technical support case for anything that you think is "wierd".
