Hello Experts,
when we define bandwidth contracts on the aruba contoller using the command "aaa bandwidth-contract guest-bw-ctr mbits 2" , basically we are saying that the traffic will be limited to 2 mbps for the guest ssid ?
so that the total bandwidth which can be given to guest users would be 2 mbps which is irrespective of the number of the users connecting to guest ?
then we go ahead and apply the following commands in the guest user role , can somebody explain what will be the difference between per ssid and per user bandwidth contracts ?
per user means that depending upon the number of users connecting to guest each user will be able to send 2 mbps up and down traffic , and the number of users is like 20 then we would need to have bandwidth of 40 mbps , can somebody clarify this please ?
user-role guest-user-role ------ is that for the entire ssid ?
bw-contract guest-bw-ctr upstream
bw-contract guest-bw-ctr downstream
user-role guest-user-role ------------------ is that for per-user ?
bw-contract guest-bw-ctr per-user upstream
bw-contract guest-bw-ctr per-user downstream
