change EIRP setting for specific AP
  • 1.  change EIRP setting for specific AP
    Posted Jun 26, 2020 09:46 AM
    we are running AOS 8.6.0.4 and for testing purpose I want to change EIRP for a specific AP not for the all group APs.
    Is this possible ? thanks
  • 2.  RE: change EIRP setting for specific AP
    Posted Jun 26, 2020 10:13 AM
    The instructions to do that will vary based on whether you are using Airmatch (you have a MM) or not (ARM).
  • 3.  RE: change EIRP setting for specific AP
    Posted Jun 26, 2020 10:38 AM
    MM - MD setup
  • 4.  RE: change EIRP setting for specific AP
