Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Contributor I
Re: channel utilization : Interference
Hi Joseph,Thanks very much for your help, it's so amazing. After i unchecked "cient-aware" and"drop broadcast..." .Channel Utilization is look better like attacment file name "channelbusy3" but it look like we get more interference than before like attachment file name "channelbusy2" and "channelbusy3". So i'm not sure due to cient-aware or drop broadcast... that bring channel utilization to be better. And from "channelbusy3" file, what should be the cause of interference lab colour "red" under channel utlization.
Thanks..
Highlighted
Contributor I
Thanks..
Highlighted
Contributor I
Hi Joseph,
Thanks for your help and it's so amazing for me. Due to after i unchecked "client-aware" and set "drop broadcast ..." following your advice, channel utilization it look better. But i'm not sure it's better from which one between client-aware or drop broadcast... .
And one thing that i see is under Dashboard > Access point > Channel Utilization > .., we will see tab colour that show TX , RX and Interference and by attachment file name "channelbusy3" , you will see a lot of  tab colour red of interference. So what should be the causes of this interference and how can i decrease it?
Thanks ..
Highlighted
Contributor I
Hi Joseph,
Thanks ..
Highlighted
You should remove channel 7 from your regulatory domain profile.
Not all interference is avoidable.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
