Hi guys,
I'm troubleshooting a problem at the moment, that I can't wrap my head around.
We are running AOS 8.4.0.4 with our MM and our 4 member 7220 cluster.
We have android phones and iPhones that connect to our 802.1X SSID, the problem only seems to exist on 2.4Ghz. The authentication works fine, but some clients connect to the wrong channel and then say that they do not have network access.
Most connect to a different AP, get an IP, then roam to the AP in question and don't work anymore. The clients stay on the same desk the whole time.
I can see the not working clients on the controller associated to the same AP as the working clients, but they associate on a different channel. I tried to manually bandsteer them to 5Ghz with the arm move-sta command, they change back to 2.4Ghz not long after and again associate to the wrong channel.
The AP in question is a 345, it broadcasts on channel 1 and most clients work fine. At the moment only 2017 Samsung A3 show these connection problems and reboots seem to help sometimes, but not always.
show airmatch tech-support ap-name XXX shows me the last channel change was by AirMatch from 11 to 1.
I have added two pictures from the show user mac XXX command, the iPhone is working, the samsung is not. The BSSID is the same but I deleted it from the screenshot.
Do you think this is just some strange driver error on the samsung or can I do something to troubleshoot this further?
I will contact TAC, I just wondered if maybe someone had some similar problem in the past.
