i have the problem with the second port of aruba 7210 controller, it is not coming up and showing up as "down" as mentioned below. not able to negotiate speed and duplex
UAM-CLCAR-MB02MDF-WC01) # show interface gigabitethernet 0/0/1
GE 0/0/1 is up, line protocol is down
Hardware is Gigabit Ethernet, address is 00:1A:1E:02:29:C2 (bia 00:1A:1E:02:29:C2)
Description: UNI_CH_CARR2_CAT_13 port 2/17 (RJ45 Connector)
Encapsulation ARPA, loopback not set
Configured: Duplex ( AUTO ), speed ( AUTO ) >>>>>>>>>>>>>>>>>>>> not negotiating speed and duplex setting automatically
MTU 1500 bytes, BW is 100 Mbit
Last clearing of "show interface" counters 3 day 7 hr 23 min 48 sec
link status last changed 2 day 8 hr 54 min 24 sec
5522239 packets input, 2874019978 bytes
Received 379533 broadcasts, 0 runts, 0 giants, 0 throttles
0 input error bytes, 0 CRC, 0 frame
95095 multicast, 5142706 unicast
2032351 packets output, 1132726950 bytes
0 output errors bytes, 0 deferred
0 collisions, 0 late collisions, 0 throttles
This port is TRUSTED
output from the switchport
un-ula-chlcar2-csw001#show interfaces gigabitEthernet 2/10
GigabitEthernet2/10 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet Port, address is 006b.f1fd.5671 (bia 006b.f1fd.5671)
Description: UAM-CLCAR-MBMDF-WC01
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Auto-MDIX on (operational: on)
ARP type: ARPA, ARP Timeout 04:00:00
Last input 2d09h, output never, output hang never
Last clearing of "show interface" counters never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
the other port of the controller works fine as usual
(UAM-CLCAR-MB02MDF-WC01) (config) #show interface gigabitethernet 0/0/0
GE 0/0/0 is up, line protocol is up
Hardware is Gigabit Ethernet, address is 00:1A:1E:02:29:C1 (bia 00:1A:1E:02:29:C1)
Description: UNI_CH_CARR2_CAT_13 port 2/16 (RJ45 Connector)
Negotiated: Duplex (Full), speed (1000 Mbps)
MTU 1500 bytes, BW is 1000 Mbit
Last clearing of "show interface" counters 3 day 8 hr 20 min 57 sec
link status last changed 3 day 8 hr 17 min 43 sec
192898313 packets input, 140627488641 bytes
Received 11496220 broadcasts, 0 runts, 0 giants, 0 throttles
5989444 multicast, 181402093 unicast
173427704 packets output, 142666827992 bytes
un-ula-chlcar2-csw001#show interfaces gigabitEthernet 1/10
GigabitEthernet1/10 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is a03d.6fc1.7029 (bia a03d.6fc1.7029)
Last input 00:00:08, output never, output hang never
5 minute input rate 4117000 bits/sec, 558 packets/sec
5 minute output rate 4056000 bits/sec, 593 packets/sec
173400473 packets input, 142647562690 bytes, 0 no buffer
Received 1265297 broadcasts (594044 multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 input packets with dribble condition detected
192867573 packets output, 140607784942 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
any help would be appreciated
