Occasional Contributor I
Re: controller selection
Soon one model should come 7205 which should
Support 256 ap maximum
For your situation it's better go with IAP model
And tunnel the virtual controller to existing controller
Contributor I
So many new things to understand.
If I have 80 radios that are not IAPs and need to add 10 more for a new campus (assuming IAPs), would the 80 controller-based APs still be able to be failed over to the IAP should the 3600 controller die?
Trying to understand how an IAP solution could work with an existing controller-based one.  I've thought in the past that you have to do one or the other, but not both.
Scott Miller
http://www.arubanetworks.com/techdocs/InstantMobile/Advanced/Content/Instant%20User%20Guide%20-%20volumes/VPN_Configuration.htm
The link would help
Use IAP access point for example IAP 103
U purchase and than would connect to network switch
It gets IP address
Provision the access point with creating ssid
Connect remaining 9 IAP
It will be in cluster maximum IAP you can connect
Is 128
Here we are using distributed architecture and only
What I need is managment plane to login to virtual controller
Which internally indicates amount other IAP
If one IAP fails other becomes master and so on
Your purpose to provide user with internet or network
Service is achived
<deleted>
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
