Highlighted
crypto-local ipsec-map uplink failover/load-balance/monitor
Could someone explain how the features:
crypto-local ipsec-map load-balance
crypto-local ipsec-map monitor
should work?
Consider we have a controller with 2 ISPs and we established two tunnels (one for each ISP to a remote VPN gateway)
will those load-balance or uplink failover feature work and how in this scenario?
Highlighted
Re: crypto-local ipsec-map uplink failover/load-balance/monitor
Highlighted
Frankly speaking the link you provided relates to
uplink load-balance while I'm asking about
As it isn't described anywhere I'm really not sure if those crypto commands are related to uplink load-balance and what are prerequesties for those crypto commands to work neither what is the purpose of those crypto commands.
It can be also worth to mention that I'm using current recommended by support sw version 8.3.0.10.
The User Guide for this sw
https://www.arubanetworks.com/techdocs/ArubaOS_83x_Web_Help/Content/ArubaFrameStyles/Dashboard_Monitoring/WAN.htm
also states that the WAN uplik status should be available while there is not such dashboard in this sw.
Although Health Check & uplink & uplink load-balance is configured:
From CLI:
uplink enable # inherited from [/mm]
uplink health-check # inherited from [/mm]
uplink health-check ip 1.1.1.1 # inherited from [/mm]
uplink load-balance media-mode # inherited from [/mm]
When I was trying to setup crypto-local ipsec-map uplink-failover
crypto-local ipsec-map azure 1000 # inherited from [/mm]
uplink-failover
causes Configuration Failure
Command: uplink-failover
Process: IKE
Message: Uplink failover not supported with ikev1
Total Failures: 1
Highlighted
I apologize that I did not understand you and I forwarded an unrelated link before asking you more specific questions.
Your original post said that you have two ISPs and two tunnels.
Questions:
- Are the tunnels terminated on the controllers or are the controllers plugged into two physical circuits or both?  I cannot tell from your diagram.
- Is this planned or this is already configured and how?
The commands you listed may or may not be the way to go.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
There is one controller (7030).
Int gig 0/0/2 is ISP1
Int gig 0/0/3 is ISP2
tunnels are established from this controller to azure VPN gateway
The relevant configuration is:
ip access-list route uplink-lb-cfg-racl
any network 192.168.210.0 255.255.255.0 any route next-hop-list azure_vpn
any network 192.168.211.8 255.255.255.248 any route next-hop-list azure_vpn
any network 192.168.211.0 255.255.255.248 any route next-hop-list azure_vpn
ip access-list route azure_vpn
interface gigabitethernet 0/0/2
description "ISP1"
trusted
trusted vlan 1-4094
no poe
switchport access vlan 600
interface gigabitethernet 0/0/3
description "ISP2"
trusted
trusted vlan 1-4094
no poe
switchport access vlan 601
interface gigabitethernet 0/0/4
description "Test"
trusted
trusted vlan 1-4094
no poe
switchport access vlan 322
interface vlan 600
ip address <public ISP1> 255.255.255.240
ip nat outside
description "ISP1"
interface vlan 601
ip address <public ISP2> 255.255.255.240
ip nat outside
description "ISP2"
interface vlan 322
ip address 10.100.1.4 255.255.255.0
interface tunnel 5
description "Tunnel azure ISP1"
tunnel mode gre ip
tunnel source vlan 600
tunnel destination <public AzureVPNGateway>
tunnel keepalive
tunnel keepalive 1 3
trusted
interface tunnel 6
description "Tunnel azure ISP2"
tunnel mode gre ip
tunnel source vlan 601
tunnel keepalive
trusted
uplink wired vlan 601 uplink-id link2
priority 100
uplink wired vlan 600 uplink-id link1
no uplink wired vlan 1
uplink enable
uplink health-check
uplink load-balance
ip default-gateway <ISP1_gateway> 20
ip default-gateway <ISP2_gateway> 20
no ip default-gateway import dhcp
no ip default-gateway import cell
no ip default-gateway import pppoe
ip route 192.168.210.0 255.255.255.0 ipsec azure
ip route 192.168.211.0 255.255.255.248 ipsec azure 10
ip route 192.168.211.8 255.255.255.248 ipsec azure 10
ip nexthop-list azure_vpn
ipsec-map azure priority 20
ipsec-map azure2 priority 10
crypto isakmp policy 20
encryption aes256
crypto-local isakmp key "******" address <public AzureVPNGateway> netmask 255.255.255.255
crypto ipsec transform-set azure esp-aes128 esp-sha-hmac
crypto-local ipsec-map azure 20
set ikev1-policy 20
peer-ip <public AzureVPNGateway>
vlan 600
src-net vlan 322
dst-net 192.168.211.0 255.255.255.248
set transform-set "azure"
pre-connect
trusted
crypto-local ipsec-map azure2 20
set ikev1-policy 20
vlan 601
src-net vlan 322
dst-net 192.168.211.8 255.255.255.248
pre-connect
trusted
At Azure I have a Vnet with 3 address ranges:
and there is a test host 192.168.210.132
This configuration doesn't work.
What I'm going to achieve is to have a redundancy between ISPs.
When routing through ISP1 will be broken the traffic should go through tunnel established with ISP2. The preemption if possible would be also nice.
The purpose why I created
was that to create separate (redundant) crypto-local ipsec-maps I have to provide different dst-net.
Without matching selectors tunnels doesn't come up.
Azure support told me that they have any to any however controller if it is not initiator will get eg.
isakmpd[3480]: <103060> <3480> <DBUG> |ike| <public AzureVPNGateway>:500-> ike_quick_mode.c:checkIpsecSelectors:3999 initRange:192.168.210.1 -192.168.210.255 policyRange:192.168.210.0-192.168.210.255 for map azure
isakmpd[3480]: <103060> <3480> <DBUG> |ike| <public AzureVPNGateway>:500-> ike_quick_mode.c:checkIpsecSelectors:4027 respRange:10.100.1.1 -10.100.1.255 policyRange:10.100.1.0-10.100.1.255 for map azure
isakmpd[3470]: <103060> <3470> <DBUG> <public AzureVPNGateway>:500-> ike_quick_mode.c:checkIpsecSelectors:3999 initRange:192.168.210.1 -192.168.210.255 policyRange:192.168.211.8-192.168.211.15 for map azure
isakmpd[3470]: <103035> <3470> <INFO> <name 192.168.222.38> Initiator IKE Phase 2 Identity doesn't match for ipsec-map azure
When Aruba controller is Initiator this would look like eg.:
Jan 17 12:35:27 isakmpd[3470]: <103060> <3470> <DBUG> |ike|<public AzureVPNGateway>:500-> ike_quick_mode.c:checkIpsecSelectors:3999 initRange:10.100.1.1 -10.100.1.255 policyRange:10.100.1.0-10.100.1.255 for map azure
Jan 17 12:35:27 isakmpd[3470]: <103060> <3470> <DBUG> |ike|<public AzureVPNGateway>:500-> ike_quick_mode.c:checkIpsecSelectors:4027 respRange:192.168.211.1 -192.168.211.7 policyRange:192.168.211.0-192.168.211.7 for map azure
