MVP Expert
Re: iAP convert to CAP on 8.2 VMC - continual reboots
Turns out it may boil down to licensing issues - my sales team hadn't had the experience of "cutting a VMC license" before,and so we think I've got the right license with the wrong encryption key.
I'll report back after I get a new license.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
MVP Expert
Getting the coorect license from my SE fixed the fianl issue.
Thanks for everyone's support on the way.
--Matthew
MVP Expert
Contrary to the documentation, the iAP converted to CAP kept trying to use aruba-master to find code and configuration even when given a specific IP address at conversion time, and assigned a specific local-master-controller. To make it work we had to redirect aruba-master from our legacy (6.4.x) to the new (8.2.x) controllers.
--Matthew
