Re: iPad 2 Issues
We do have an open SSID available with limited access to internal resources but the problems are present when connected to an 802.1x authenticated network with mixed mode encryption.
Re: iPad 2 Issues
Yes. For my iPad 1, it didn't matter what kind of encryption was being used, as here on our campus we have three right now (open, wpa2-psk, wpa2-aes). This just further proves my belief that this is an Apple issue.
Zach
Zach Jennings
Re: iPad 2 Issues
James, do you have a TAC  case open for this already?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Re: iPad 2 Issues
This solution seems crazy, but I saw this on an Apple forum.  This may not even be the exact issue you're seeing.
https://discussions.apple.com/thread/2391395?start=0&tstart=0
Re: iPad 2 Issues
The last post in that forum is a year old, unfortunately.  If a TAC case is opened we can certainly target that.
Re: iPad 2 Issues
We've got a call open with our supplier, I'll ask them to log a TAC case with Aruba.
I've also now had a report of an iPad 1 with the same issue.
Re: iPad 2 Issues
James,
Let us know if you still see the issue in iOS 5.0.1.
Zach Jennings
Re: iPad 2 Issues
That would be good. If you want to do some debugging yourself, this is what we can do:
Turn on debugging for that device:
config t
logging level debug user-debug <mac address of device>
 Next, connect the device and disconnect normally.  Then reconnect, replicating the behavior you mentioned before.  Lastly, obtain the logs for that device:
show log user-debug all | include <mac address of device>
 Assuming that you can replicate the issue, we can at least get an initial picture of what is happening from the logs.
Re: iPad 2 Issues
Will do, I'll let you know how I go on Monday.
Re: iPad 2 Issues
It looks like the update to 5.0.1 has done the trick. I've been conected all day without a problem. We'll see how it goes tomorrow before we declare a victory!
In the meantime I have advised other users to upgrade.
