Re: iPad 2 Issues
@James Holland wrote:
It looks like the update to 5.0.1 has done the trick. I've been conected all day without a problem. We'll see how it goes tomorrow before we declare a victory!
In the meantime I have advised other users to upgrade.
Awesome news!
I thought I hadn't seen it since I went to 5.0.1, but I didn't want to say for sure. I honestly can't remember the last time it happened, which means it was likely prior to the 5.0.1 upgrade.
Zach
Zach Jennings
Re: iPad 2 Issues
Just to confirm that it looks like upgrading to iOS 5.0.1 has solved the problem. Thanks for your help:smileyhappy:
Re: iPad 2 Issues
did you tried the IOS 6, i'm facing this strange issue with ,y ipad-2 and 6.1.1.0?
Re: iPad 2 Issues
Hi, I haven't tried iOS 6.1.1.0 yet so am not aware of any issues. What are the symptoms?
Re: iPad 2 Issues
I've just checked and the latest version appears to be 5.0.1 so I'm not sure where 6.1.1.1 has come from????
Re: iPad 2 Issues
This is correct. I also had the same problem after upgrading OS for my Ipad 2.
