Highlighted
Re: ipsec between aruba controllers
Hi Pete,
You can setup a VPN tunnel between the controllers first and within that tunnel you can create a L2 GRE tunnel to transport the vlan between the sites.
Jonas
Highlighted
Regular Contributor I
thanks Jonas for getting back to me.
i guess this is something i can try in our lab.
Is it setup you have tried?
Highlighted
Pete,
Yes, I have tried it and used it in production deployments too.
/Jonas
Highlighted
thanks Jonas,
do you have a config doc for this?
Highlighted
Hi Pete,
We do have a solution for this in Aruba Solution Exchange.
https://ase.arubanetworks.com/solutions/id/116
This will help you create the config and also have it documented :)
/Jonas
Highlighted
this certainly looks like what i need.
can i just clarify:-# in the configuration notes below it says set up the GRE tunnel with the same Source/Destination networks as IPSEC.
Is this right?
CONFIGURATION NOTES
Site-to-site IPSEC vpn is configured with source/destination networks on the private Vlans. L2 GRE is configured with the same Source/Destination networks as IPSEC.
At headquarter, Controller also has private/public Vlans. Guest users in a private vlan. Guest Vlan is extended to Guest anchor controller through L2 GRE.
At Datacenter/DMZ, guest anchor controller has both private/public Vlans.
Highlighted
Yes, you should build the l2 gre tunnel between the inner IPs of the IPSEC, so in that case it is correct. So you should not for example set source/destinations network for the gre as the network tunneled over. controller dont care . Depending on what you are trying to achive, you then redirect traffic into that tunnel based on role or similar. I think it was a role config for redirecting traffic into the tunnel in the solution.
/Jonas
Highlighted
thanks Jonas,
here's my thinking:-
Site-site between controllers with the public IP addresses of the headquaters and DMZ as the destination ip.
GRE tunnel between the controller provate ip addresses.
how does this sound?
pete
Highlighted
Jonas,
tried out that solution works just fine thanks for your help.
cheers
pete
View solution in original post
Highlighted
MVP
Please accept the best post(s) as the solution then please. Helps those that come after :)
Koen (ACMX #351 | ACDX #547 | ACCP)
-- Found a post helpful or important? Click the "Thumbs Up" icon to give kudos.
