This community is currently in a read-only state due to a maintenance window. For more info click here
Highlighted
Re: multiple vlan on captive portal issue
The current release notes for ArubaOS sets the limit to 512.  There is no indication that will ever change.  The internal DHCP server is only intended for small guest networks.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Super Contributor II
But I remember once i configure /16 Pool and 3600 series controller allowed me to do so..
May be the reason is that, controller allows to configure Pool of any limit but it do not provide addressed to more than 512 devices.
Is it ?
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Highlighted
It does not restrict you from configuring it, but you will run into problems down the road if it exceeds more than 512.
Highlighted
Got it . Thanks :-)
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
