Contributor I
Re: old registered and down AP not shown on the controller
I can't find any clear button on the controller,
the down AP does not have IP address
is there any way to login to the AP and configure it manually like adding static IP address or reset it to default setting .
CISCO AP can connect it directly to the PC and configure it or reset it to default setting
M. Alajeely
When using the console, stop the AP at the apboot> prompt and then type "purge" and press enter.  Type "save" and then press enter.  That should purge the AP.
You can also set the AP parameters manually by using the "setenv" command:
setenv ipaddr <ip address>
setenv netmask <subnet mask>
setenv gatewayip <default gateway>
You also need to point the AP to the address of the master controller:
setenv master <master controller ip address>
After that type "save" and then "boot"
To see what parameters you have, type "printenv"
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Huh, then I guess the "Clear" button must have been a 5.x addition.
Zach Jennings
Contributor I
Thank you for the details
I got the clear button, its on the very write side of each down AP when you open them, you need to zoom out the window to see it.
M. Alajeely
